Just reprogrammed my alarm code on my 2005 Softail. Alarm is working fine with both fobs. I understand the procedure for disarming without fob is: turn on ignition then press signals (both at same time) until I see dashes on odometer. NOT working. Never see the dashes. Any ideas appreciated!
set run switch to off. turn ing key to acc hold both turn switches security lamp blinks fast rate. then press left switch number of times u want 0-9 then press right one time repeat five more times. if u get it rite security lamp stops blinking
