Clutch Hub Issue
Clutch Hub Issue
Hey all,
91 FXSTC Softail Custom
So after doing a handlebar change, when I was about to adjust the clutch cable, found that the nut that holds the center bolt was way too tight. Finally able to take it out but then realized that the clutch hub outer teeth that hold the outer plate together were worn off.
Ordered a new clutch hub which came in and installed it.
Put everything back together:
so it looks like this:
and when I made the adjustment to the clutch cable and pressed it, it moved all the plates forward, outer lid(plate?) popped off and damaged the teeth again...
Defective clutch hub or something was not installed correctly? Seems like it's an aluminum part with tiny teeth that is supposed to hold a lot of pressure on those tiny teeth so kinda lost at the moment
Any help is appreciated.
Know when I took mine apart, I pulled in the clutch just slightly to remove snap ring. But mine only holds the adjuster plate. What actually holds mine all together is 6 bolts. Hard to believe that groove holds the clutch diaphragm spring back.
Did you do the following order and all parts? That is a pretty expensive part. I do not see two grooves in your part. Do you have correct part????...https://www.dodgecityharleydavidson....(1991)//CLUTCH
yeah when I select my bike model/year (91 FXSTC) on JP that's the only one that comes up:
https://www.jpcycles.com/product/630...win-clutch-hub
The ones with the bolts seem to be for later years... can't seem to find any aftermarket clutch hubs for 91 googling...
Is it possible you have the ***** in the rams out of position on the transmission side where the clutch cable goes in. That would push the clutch in too far and when you cranked in the adjuster, to pulled off the top of the aluminum. Seems you would have had to screw in adjuster with a wrench to do that. After I brake the lock nut, I use my fingers for the adjuster.
