2006 Deuce DNA 18x5.5 spoke issue
Old 05-13-2018, 10:36 AM
bigdaddyeo's Avatar
bigdaddyeo
bigdaddyeo is offline
Stage III
Default 2006 Deuce DNA 18x5.5 spoke issue
Finally got around to installing a DNA 18x5.5 60 spoke that I bought through Ebay 6 months ago on my 06 Deuce. I was all prepared to play around with some 3/4" PVC and mock up some custom spacers but strangely enough the existing spacers put everything right where it needs to be... except the tire. The caliper sits perfectly over the disc, the belt appears to sit and track on the pulley properly but the actual outer rim and tire appear to be 1/2"-3/4" offset to the right.
It has me thinking that maybe the existing spacers will need to be taken out and have custom ones machined but I can't move the hub/pulley any to the left as the pulley will hit the swingarm and then I would also have to shim out the brake caliper. Maybe I need to do the thinner pulley/belt and then spacers/shim?
Anyone run into this? DNA model number for the wheel is specifically for the Deuce. Any suggestions would be welcomed.
muttboy
01-16-2017 03:56 PM
Half-Fast Deuce
06-11-2013 06:13 PM
deuce06
05-05-2010 04:58 AM
ezmoney
21
06-30-2008 05:41 PM
DeuceRyder
05-19-2008 02:53 PM
Quick Reply: 2006 Deuce DNA 18x5.5 spoke issue
