Removing Rear Backrest on 2017 Heritage softail
I want to remove the rear backrest on my Heritage Softail. I’ve removed the saddle bags. If I remove the saddle bag bolts totally are there captured nuts that will keep them from falling through after I remove the bolts. Not much room between the fender and the tire
Joe
Joe
I am not good at explaining so bare with me. Doing both sides at the same time loosen all 4 bolts, then remove both sides the same bolt and lift the mounting brackets ans replace the bolts. Then remove the second set of bolts and remove the complete backrest and brackets. replace last 2 bolts and tighten all 4. Good Luck
Southj (04-17-2018)
I loosened the four long bolts the went into the bags. I completely removed the the rear two of these bolts but the backrest did not pivot forward so I could put those two bolts back in . Do you have to remove the small torx head bolt at the very rear of the plate for the bracket to pivot ? I hope not cause I could not get it to budge.
Thanks guys for helping me out. I feel stupid I can’t get it done.
