Flush Mount Fuel Gauge
I just installed a HD Flush Mount Fuel Gauge that I bought off E Bay and it seems to work fine but I did not get directions with it and I am wondering if the center LED that is now glowing blue ( I have a 1/2 tank of fuel) will will change color as a low fuel indicator as I run low on fuel ? I know the line of LED will go down as I use fuel, I'm just wondering about the LED above the line of LEDs?
Thanks for any info.
RE: Flush Mount Fuel Gauge
yeah you just kind of confused the hell out of me as to exactly what you're asking.. but I'll try it out. You have the blue lights, when you get down low, you'll have 2 amber lights I think it is, then they'll blink, then they'll go to Red, not exactly all that accurate on my bike anyway, cause I hit red for a bit and still kept going for a few more miles, havent ran out yet. Hope that helps to what you're asking.
ORIGINAL: Deuce Bigelow
you have all blue LED's, the "center blue" LED is a gas pump icon, it will never go out and doesn't indicate anything.
ALL LED's are blue, they don't change color when you get low on fuel, when you have only the last blue LED lit, look for fuel!
ORIGINAL: 06hog
Yeah sory Deuce, but I guess you either dont have it hooked up correctly, or you just never ran that low on fuel. Caue mine does change colors, made from Harley also... ALL LED's are NOT blue
there are two different version Flush Mount gauges.....
you guys have the "softail" version, it has six blue LED's and one red LED for low fuel (you also need to hook up that stupid grey wire into the speedo for the low fuel)
I have the "touring" version flush mount gauge, it has seven blue LED's, and NO low fuel warning, and it also has an LED "gas pump" icon that lights up when the ignition is turned on, and my low fuel light in the speedo still works...........
I bought the touring version because it doesn't have a low fuel LED in the gauge![8D]
based on the description that XARAN gave, It sounds like he has the same flush mount gauge that I have, therefore NO red low fuel LED, all seven LED's are blue!
XARAN,
if you have seven blue LED's (when you have a full tank of fuel) and a blue "gas pump" LED, then you have the "touring" version gauge, the softail gauge does not have that "gas pump"icon LED above thefuel level LED's, and the softail gauge onlylights upsix blue LED's when you have a full tank of fuel.
ORIGINAL: cubcake1
1/2 of my led's just failed after 38 days. The stealer will not exchange so I am looking for a reliable alternative.
