Stuck bolt broke off
Old 03-25-2018 | 11:15 AM
matte's Avatar
matte
Originally Posted by Ed Ramberger
If you are going to drill use a reverse drill bit and do not use a tap - if you need to clean up the threads use a thread chaser.
Taps cut new threads, chasers clean them/straighten them up.
that's some good info. It's only about a quarter inch of thread that's affected. So will make sure I do that.
Old 03-25-2018 | 11:18 AM
moparnut72's Avatar
moparnut72
I agree on the reverse (left handed) drill. Easy outs really are not the best way to go. They actually expand the bolt or stud and make it tighter in the hole making the stud harder to remove. McMaster Carr will have one and they have a quick turn around.
kk
Ed Ramberger's Avatar
Ed Ramberger
If you could access the backside of the hole - if it isn’t blind - that would be where to start the thread chaser
Old 03-26-2018 | 08:02 AM
matte's Avatar
matte
Drill appears to be a no go. Gonna try to go the nut welding route this week. right and left hand bits don't seem to be making any progress.
Old 03-26-2018 | 08:11 AM
Serdvd6's Avatar
Serdvd6
Good Luck!
The following 2 users liked this post by Serdvd6:
Campy Roadie (04-12-2018), TwiZted Biker (11-02-2019)
Old 03-26-2018 | 08:15 AM
Rick03's Avatar
Rick03
1st Gear
Default Good luck, hope it comes out easy
I would use pb or if you can get kroil penetrating fluid it's much better. Vise grips and wiggle back an forth to try an free it up
Old 03-26-2018 | 09:55 AM
TeaRunner's Avatar
TeaRunner
Sacrificing a chicken or goat to Odin never hurts either.
Old 03-27-2018 | 07:48 PM
Ed Ramberger
Ironically today at work I had to extract a left threaded bolt that someone had tightened until it broke because they thought lefty meant loosey in all situations.
Because it was reverse threaded, a normal drill bit was what I needed to use. By the time I saw it, an attempt had been made with a larger drill bit and it was off center. I showed the tech how to start with a very small diameter and re-centered and drilled. Then step to one larger and then on the third bit it caught and spun it right out. Gotta love it when it works like that.
Old 04-03-2018 | 07:49 AM
matte's Avatar
matte
Well after a rough weekend of trying to drill that sucker out, we broke through and realized we were way off center and we're going into the threading and body. Thankfully I found a replacement Swing arm online for 135 shipped. Expensive lesson but cheaper than a brand new swingarm are 900 bucks.
Old 04-03-2018 | 08:59 AM
Bluraven's Avatar
Bluraven
That's exactly where I was at.
Before I embarked on trying to get my broken shock mount bolt out I did some shopping and found a swing arm online for around $150.
So I figure other than $150 I didn't have anything else to lose so I just went for it.
I didn't try to the welded nut method, but I did try the backwards drill bits which didn't work.
The easy-out worked so I got off cheaply.
Glad you're getting it back together.
Ride Safe...
Quick Reply: Stuck bolt broke off
