Need Blackline owner "Yes" or "No" answer
Old 03-19-2018, 08:00 AM
Burbur2's Avatar
Burbur2
Burbur2 is offline
Default Need Blackline owner "Yes" or "No" answer
Sorry for cross posting but no luck with my original post most likely due to title.
Can someone with Blackline model let me know if rear brake set up and brake line looks the same as on below pictures? Yes or No will do. I try to install 2" extension for forward controls onmy Slim (converted to FXS set up) and instruction say I can reshape brake line (metal tube part) and no special brake line is needed for Blackline set up but this looks like really tight fit already so I want to make sure is what you see is also Blackline version or maybe brake line on Slim is different on Slim comparing to Blackline.
Hope someone will let me know. Pictures will be even better especially from front of rear master cylinder and top so I can see brake line and verify.
Thanks in advance
Old 03-31-2018, 12:06 PM
kansei's Avatar
kansei
kansei is offline
Yes looked at mine and its routed the same.
Old 03-31-2018, 12:13 PM
Burbur2's Avatar
Burbur2
Burbur2 is offline
Big thanks. I am done with my 2" extension install. What a great upgrade now I am more comfortable. For a moment I thought about going back to boards but pegs gave me more room so it stay. I had to gently bent the brake line but it worked great at the end. Super happy about this change
Nagy
08-05-2013 12:02 AM
04-13-2010 08:43 AM
gsgtrman
05-26-2008 11:38 AM
HarleyArcher
02-20-2008 07:16 AM
hdxl1200r
08-28-2006 10:40 PM
Quick Reply: Need Blackline owner "Yes" or "No" answer
