In my excitement to install the lay down license plate holder and CD Led turn signals, I removed the rear tire so I could reach the bolts and run the wires. Now hours later I can't recall the proper sequence for the right side spacers and how to route the ABS sensor wire. I ordered the manual, but it's not coming until Feb 15th. Help brothers. I need a few pics for the R side spacers, and how to route the ABS wire off yours or a pic if someone has the manual.
Here is the assembly drawing from the 2018 manual.
Hope it is of use for you. Will try to get a good picture of the page with the torque values to reassemble it all.
Edit: easier this way: Rear axle nut: 95 - 105 ft-lbs
I toughed it out by leaving everything in tact and sticking my hand/arm between tire and fender. Was it tight? Yes. Was it at times painful....yes. But it worked.
Honestly that idea never crossed my mind. I would have been afraid of scratching the paint anyway.
yeah.. will have to give it to you there.. even the slightest of touch scratches that bloody paint.! my dog sniffed it, I wiped it off with a dry towel. boom. scratch. mines black btw.
