Installed New Samson Exhaust - Have a few Concerns
Old 01-29-2018, 10:50 AM
dsalazar63's Avatar
dsalazar63
dsalazar63 is offline
Default Installed New Samson Exhaust - Have a few Concerns
So over the weekend I installed a Samson true dual 33" fishtail exhaust on my 05 Deluxe. I first want to say they look totally bad *** and sound awesome !! It took me a little longer than I expected to do the install, but overall it wasn't to bad. It took me about 4 hours but I took my time use painters tape on all the chrome to avoid scratches.
So, after I got everything buttoned up, I fired the bike up. Sound was absolutely incredible, but the head pipe that comes from the rear jug and runs across the primary got extremely hot, really fast. I'm concerned that this kind of heat next to my leg is going to be a problem, also is this going to be to much heat on the coil and oil tank ? Anyone of you Samson guys burn your leg ?
I took off a set of V&H wide radius short shots and the bike was tuned by the dealership for stage 1. Do I need a new tune to go along with these pipes ? They do not have a baffle or muffler, just like the short shots.....
Old 01-29-2018, 01:52 PM
Carlos G Godfrog's Avatar
Carlos G Godfrog
Carlos G Godfrog is offline
Don't you have heat shields ?
Old 01-29-2018, 01:53 PM
dsalazar63's Avatar
dsalazar63
Yes, the heat shields are attached. The pipes are beautiful, almost a work of art, but damn they are hot !
Old 01-29-2018, 02:55 PM
uncle kebo's Avatar
uncle kebo
uncle kebo is offline
Received 4,902 Likes on 2,431 Posts
I had these on my 04 HSTC, and never had an issue..
Attached Thumbnails Installed New Samson Exhaust - Have a few Concerns-hd4.jpeg
dsalazar63 (01-29-2018)
Old 01-29-2018, 03:47 PM
FrozenInTime's Avatar
FrozenInTime
FrozenInTime is offline
Been running mine quite awhile, never burned. Did you put torque cones in with yours? I did air filter, no cones, SERT and had it dyno'd 3 times. Best they could get me to was 64 horsies. I still love them, nice pipes.
Old 01-29-2018, 03:50 PM
FrozenInTime
Old 01-29-2018, 07:07 PM
gregeinsc's Avatar
gregeinsc
gregeinsc is offline
Yeah you better get used to having the same spot on your left calf burned over and over again unless you have a long inseam. Form should always follow function
Old 01-29-2018, 09:19 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
I installed V&H softail duals on my '15 slim an it got pretty warm on the left thigh so I removed the heat shield an wrapped that section of the pipe with exhaust wrap an secured it with safety wire an put the heat shield back on. I can still feel it a little but it's no big deal now.
Old 01-30-2018, 06:13 AM
Maltesefalcon's Avatar
Maltesefalcon
Maltesefalcon is offline
Never had an issue with mine I mean they do get hot but not the way your describing yours. I to have the 33 inch on mine with the Power Vision from Fuel Moto.So far never burnt my leg either.
Old 01-30-2018, 06:37 AM
Rakthi's Avatar
Rakthi
Rakthi is offline
Tuned for stage 1 ... did they just put on the canned tune or did they "tune" it properly for open pipes? You might be running too lean an thus pipes get very hot.
Had the V&H Duals on my Xbones in the tropics and never experienced heat coming of the left pipe as you describe it.
Quick Reply: Installed New Samson Exhaust - Have a few Concerns
