Bike won’t start fuel pump not kicking on
Old 12-29-2017, 10:22 AM
Antonio 888's Avatar
Antonio 888
Antonio 888 is offline
Stage III
Default Bike won’t start fuel pump not kicking on
My 09 Softail won’t start. when I turn to run fuel pump does not start, and blinker lights alternate flashing. Key fob battery is new. Any help is appreciated
Old 12-29-2017, 11:36 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
I would start checking fuses.
Old 12-29-2017, 12:45 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
Check the fob battery .... it's easy to install upside down ... a somewhat common mistake. If that doesn't work, try using your PIN to disarm the security system.
Old 12-29-2017, 01:49 PM
Antonio 888
Stage III
Fuses are good . I have nothing on my brake side controls. My blinker won’t even work. I wonder if I knocked something loose when I tried to hook up speakers.
Old 12-29-2017, 03:47 PM
saltlick's Avatar
saltlick
saltlick is offline
its probably the wiring that plugs into the main wiring harness under the tank on the right hand side. If that comes loose or if you messed with it while doing the speakers thats the reason
Old 12-29-2017, 05:12 PM
FreedomRider's Avatar
FreedomRider
FreedomRider is offline
is your Run Stop switch in the Run position?
j33ptj (01-01-2018)
Old 12-30-2017, 05:16 PM
mplazz's Avatar
mplazz
mplazz is offline
If you have recently un-plugged the 3-pin connector underneath the console, then re-connected it, you probably have bent pins in the connector now. They bend very easily. Ask me how I know.
Old 01-01-2018, 08:33 AM
j33ptj's Avatar
j33ptj
j33ptj is offline
Are you in gear with the stand down?
Old 07-03-2019, 01:44 PM
crusader1xxx's Avatar
crusader1xxx
crusader1xxx is offline
Come on guys its mechanics 101....fuel and spark...go from there, regardless of who is asking....also aftermarket batteries should have those little adapters...use them otherwise the battery cable ends won't sit flush with the posts and cause all kinds of chaos....
Old 07-03-2019, 04:18 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Pitbull_Dallas is offline
Even with a bad fob or no fob the fuel pump will run (at least on my 07). It just won't crank and the flashers will blink. I'm betting something got knocked loose, but Harley connectors are very hard to disengage.
On the fuses, did you just look at them or check them with an ohm meter? They can look good, but not be..
Quick Reply: Bike won’t start fuel pump not kicking on
