Anyone put a Metz 90/90 on the front of their Train? If so, did it change the handling? How did you handle the Tube situation? Would you recommend it? Does having the Factory up-grade wheels make a difference? I'm also planning on changing the rear at the same time. Where did you buy?
you'll feel a big difference with the 90/90. like George says they should come with that size from the factory. Depends on the wheel mag/spoke for the tube or tubeless.
I put the 90/90 x21 on my WG which is essentially the same set up , love it , while not as elegant looking , it handles WAY better in the twisties and 2 up
I have a Metzeler ME880 90/90 H21 on the front of my Train. Handles way better than the stocker! And I like how it fills more of the space between the tire an the front fender. No mods are required to go to this size. It'll fit on the stock rim using a regular inner tube.
Thanks for the help guys, I went to my dealer today to see about having them mounted, he said that the 90/90 is a tubeless tire, how did you guys handle it?.. I have spoked wheels.
Just get them to put a tube in it. You need one for the spoked wheel, and it's ok to use tubes with tubeless tires (not the other way 'round though!). Get a new rim band too. Thta's what I did with mine.
