For anyone that has lowered their bikes! Test rode a bike that has been lowered 2'' and with not being experienced with a lowered bikes I did get some scrape on making a turn. Love the look but not sure it's worth the safety concerns! Do you get used to the maneuver limitations or have you just returned your bike back to specs? Appreciate the input!
I have a 16 Deluxe, I lowered it 1 inch front and rear, no problems at all, I don't ride aggressively. Progressive customer/tech service didn't recommend more then 1 inch drop.
I went with 422's in rear and Mono tubes in front, bike rides much better and no nose dive in braking.
I lowered my deluxe and love the look. I did this temporarily until I can afford to do an air suspension. I have 2 kids going into college so it was obviously more economical for me to lower it right away and slowly save for air.
Anyway, I did the progressive drop in's in the forks and the bushing kit from Dead Creek Cycles. 2" up front and 1.5" in the rear. Honestly, it did change the ride, but it's not bad at all. Its just a little sharp over bumps in the rear but nothing that would make me want to return it to stock. The front is perfect, no more nose diving when braking. I've only scrapped my floor boards 1 time, like the poster above, I'm not a real aggressive rider. I like to drive slow and low......
I like the look, but not the result. Here in Central California at the base of the Sierras, there is some of best curvy roads around. Not much traffic, and spectacular scenery. I've kept my Deluxe at stock height, and even tho I am far from aggressive in my riding (I get passed by most sport bike riders that come from behind), I still scrape the 'boards frequently.
Some day, I may put the air ride on the rear, so the bike can be lowered for in town cruisin'.
Lowered 2" front and rear on my Slim. If you learn to use your body more in the turns you don't really have an issue. Just watch this video of the bike in Colorado.
Hi
I'm thinking of lowering my Softail Deluxe 2006 1" front and back just like you did. What kits do you recommend to use for both back and front? I often ride with my girl in the back. Want to make sure it stays as smooth and safe as now with stock settings.
Also I see "422's" and "422" mentioned here and there... Is there two kinds of 422? If so what is the difference?
Did the exact same thing to my Heritage. MUCH better than stock and I would never go back. Plenty of clearance.
Hi
Thanks!
As the poster said.. he has Progressive mono tubes in front. There are Progressive 422 and 422 RAP. The RAP version has a **** that allows you to change preload by turning it.
