Trans fluid change with Legend Air Ride
Last winter I had my local dealer install the Legend Air Ride system on my 07 Deluxe. Its time for a 3 hole fluid change before I put it away for the winter. I've got the engine and primary changed but the air ride system blocks access to the drain plug. Any one know how much I have to remove?
I leave the shocks in place and run a paper towel or toilet paper roll in between them, then use a socket on an extension thru the roll to remove the plug. The tranny fluid drains down thru the roll into a drain pan.....easy and eliminates the mess!!
With the Legend Air Ride on my Breakout, I'm able to just push the line that runs over the drain plug off to one side, it moves just enough to get a socket on the plug.
You can do it, just barely.
I have a 2011 FLSTC. After installing the Legend REVO-A rear shocks, I had to at some point replace tranny fluid. I was pretty pissed when I realized that when I looked under, the shocks are so close, there is no access to the tranny drain plug. But this is what I did, and I had NO MESS. You have to do it just right though. I use a motorcycle floor jack (the Big Red Motorcycle/ATV jack to be specific) with the Harley frame rail cushions (need them for softails). Jack up the bike, make sure you place the jack in a spot that will allow access to remove the shock mount nuts that are under the engine/tranny. Remove those nuts. Put a jack stand under the front wheel (prevents any tipping when jacking up the rear wheel). Then using another floor jack (like one for a car), jack up the rear tire till the swingarm just touches the bumper, DO NOT JACK FURTHER. If you look underneath, now the Allen socket in the drain plug is just barely accessible because the shocks were moved back when the rear tire was jacked up. If you allow for just a tiny bit of a tipped forward angle of the bike, when you remove the drain plug, the oil will drain out just in front of the shocks, but not on them. No mess. I was about to give legend a piece of my mind if there was not a way to do it cleanly (just barely).
The following 2 users liked this post by S.D.M.F:
jkinner (01-02-2023),
Maltesefalcon (01-05-2023)
VTwin-Goodies
Air Suspensions
01-08-2010 02:49 PM
