2012 Fatboy Lo battery light flashing
There are other members more mechanically inclined than myself, but the alternator would be my first guess. That battery isn't being properly recharged and is just being drained much of the time during operation. No way it should be done in one month.
Get the alternator checked.
Can you jump start and then ride?
Charge the battery, start the bike. Check voltage at the battery. If it isn't 13.5+ at idle, going up to over 14 when you rev a little, you have a charging system problem. It could be the stator or the voltage regulator if that is the case.
The battery light flashes when voltage is too low for a period of time (I think 5 minutes) when the bike is running. It does not indicate a bad battery, but a bad charging system. Does the light go out when you are running at higher speeds?
You should also check the code that was set - it's likely voltage too low.
