04 night train rear wheel
I just picked up 04 n train, and the rear wheel spokes are coming out of the rim. I have never owned a street bike with spokes, [plenty of dirt bikes] I am curious to rim options I have on this. Or replacement of spokes. I believe it is a 5.5x18. it has a 180 tire on it. I went to ronnies to look at the wheel, but no part #'s available.
sounds like you don't have a stock rear wheel. I believe the factory wheel was a 16x3 Fatboy wheel with a black center. So the spoke is a replacement. if you have a 5.5" wide wheel some changes were made to accommodate a wider rear tire. pics of the back would help. a 3/4" sealed bearing wheel was used then so unless the previous owner did major modes any early-mid 2000's wheel will work.
if a lot has been changed order a replacement in the same size or have that wheel respoked.
svarnster (10-13-2017)
seat is not bolted down. It came with a new lepera seat and I was just checking it out. Battery is dead as well so I didn't see the need to attach it. I found the rim info it is a rk excel rim 18 x 5.5 it is missing 6 spokes. I am having a hard time finding spokes to fit it so far. I am hoping to break it down, add spokes and go from there.
