Wiggle
Old 10-11-2017, 06:25 AM
tafdeluxe's Avatar
tafdeluxe
tafdeluxe is offline
Default Wiggle
Doesn't happen all the time, but I'm experiencing what is best described as a wiggle. It feels like the rear wheel breaks loose for a second. Due to absent mindedness my steering post was not regularly greased. Although it feels like the problem is in the rear, I'm wondering if this can be the issue. I also thought maybe the bushings on the swing arm (is it still called a swing arm on a softail) could be the problem. It also has been suggested that my spokes are loose or in need of swapping. I have a little trouble with that theory. Checked the spokes and fine, but not on a stand. Thoughts?
Old 10-11-2017, 06:29 AM
FLSSBart's Avatar
FLSSBart
FLSSBart is offline
I'd check;
Tire Pressure front and rear
Axles bolts are tight
Brake caliper bolts are tight
Check if there is wiggle in the wheels like the wheel bearings are going out
Check the steering head bearings. An easy way is to ride and come up to a stop somewhat quickly. If you hear a clunk it could be the steering head bearings
Make sure shock bolts are tight (to spec)
Thats where I'd start.
Old 10-11-2017, 07:05 AM
Hacksaw580's Avatar
Hacksaw580
Hacksaw580 is offline
Don't forget to check the swing arm bearings.
Old 10-11-2017, 07:14 AM
tafdeluxe's Avatar
tafdeluxe
Thanks for the replies so far and future ones. Did check the easy ones like tire pressure right away. Got to get it in the air for the others. I don't hear a clunk but there does appear to be some slight movement on the steer post. Need some time to check the rest.
Old 10-11-2017, 11:04 AM
jkinner's Avatar
jkinner
jkinner is offline
Tires worn? Are you on the throttle when it happens(tire breaking loose), Mine will do that on a certain stretch of road here locally. (2016 Deluxe).
Old 10-11-2017, 11:41 AM
vizcarmb's Avatar
vizcarmb
vizcarmb is offline
Also check your throttle control
Old 10-11-2017, 12:00 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,322 Likes on 3,178 Posts
Could be the nut that connects the seat to the bars.
Old 10-11-2017, 05:06 PM
tafdeluxe's Avatar
tafdeluxe
Default Shot?
I'm assuming and we all know what happens when you assume, that is a shot. If it is original material, very creative. If not please pass the compliment along to the appropriate recipient.
To all the other posters thank you. I'm in the process of eliminating all the suggestions.
Old 10-11-2017, 06:11 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Just light humor. Nothing personal
Old 10-11-2017, 06:15 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
How old is the rear tire? Could be belt separation, rare but it happens
Quick Reply: Wiggle
