21" front wheel question
Seems like a lot of selections for 21" front wheels on Fatboys up to 2006
What's different about later models? I have a 2008 and there are much fewer choices.
Found this on Ebay. Can it, or my bike, be modified so it'll work?
http://www.ebay.com/itm/BLACK-60-SPO...19.m1438.l2649
I believe it's the bearings installed. 2006 down have 3/4" bearings...I'm not sure if your bike has 1" or 25 mm....if it uses 1" axles 1" bearings are a easy swap into the wheel...if 25 mm I'm not sure....
I just checked an looks like your bike uses 25 mm bearings an axles. I bet you can use it but tracking down bearings might be hard. from what I've read you want to replace the bearings that come in those lower priced wheels on ebay anyway.
Can you give me a link or where to get them?
no problem. here you go:
very easy install. they simply slide into the bearing and reduce the size down to 3/4" to fit your axle.
i have been running them for about 6 months with absolutely no issue. i also spoke with a tech from my local HD dealership. he said he has used them many times and would not hesitate to use them on his own bike. that was enough of a testimonial for me.
joebotics
09-29-2013 05:16 PM
