Axle Mounted License Plate Installed
Old 10-02-2017 | 07:47 AM
EricRay's Avatar
EricRay
Originally Posted by MocityFB
I prefer your axle mount setup to the other swing arm setups I have run across. I just recently purchase 18 FatBoy. May I ask where you purchased the holder and part number? Also is the left rear turn signal closer to the fender since the stock holder was part of the turn signal stalk? I cannot tell from your picture.
I bought the stock standoff signal bracket to match the right hand side, here is a list of the parts I used:
Custom Dynamics License Plate Frame: http://www.ebay.com/itm/Custom-Dynam...-/162357184084
Accufast Axle Mount Bracket: http://www.ebay.com/itm/HD-Custom-Dy...item25dfffbc69
Harley Davidson Turn Signal Standoff: P/N 69438-06
Old 10-02-2017 | 08:00 PM
Roadstrdude's Avatar
Roadstrdude
Tag with LED running and brake lights..<br/>
Old 10-02-2017 | 09:58 PM
MocityFB's Avatar
MocityFB
Stage IV
Thank you sir!
Old 11-04-2017 | 07:16 PM
fat daddy's Avatar
fat daddy
Originally Posted by Puttnutt24
Another option...
Kuryakyn Gloss Black Nova Vertical Side Mount..
Clean install/looks
Bright as hell..
Is the wiring for your lights coming down on top of the swing arm. Looks very nice.
Old 11-05-2017 | 12:50 AM
kiwideuce's Avatar
kiwideuce
winner!! best light set up,do they act as tail light and brake light and what product is it
Old 09-14-2018 | 06:52 PM
kgibson90's Avatar
kgibson90
3rd Gear
Sorry for not being able to PM you, but I'm a complete amateur with modding and wanted to know level of effort to do this? What steps were involved, rerouting wires, etc.?
Old 09-15-2018 | 06:22 AM
uncle kebo's Avatar
uncle kebo
The swap is simple the pain in the a$$ to me was the wiring.. Not too bad but I had a few head scratches along the way. While I was there I also changed the reflector under the fender to a light that works as the 3rd brake light. That compounded the effort..
MOST IMPORTANT - HD sells a spacer that you put btw the rear clutch side light and the base so it evens out with the other side. Thats a must get..
Old 09-15-2018 | 06:31 AM
kgibson90's Avatar
kgibson90
3rd Gear
thanks for the reply, the wiring is what has me the most worried. Is soldering involved? EricRay mentioned cutting wires, and having to slide plugs out.
Old 09-15-2018 | 09:37 AM
TUFF LUCK's Avatar
TUFF LUCK
Lots of good info here. I was looking for plate options last night glad I ran across this one
Old 09-15-2018 | 09:52 AM
AbqDave's Avatar
AbqDave
That looks awesome. It's cafe-racer awesome.
Quick Reply: Axle Mounted License Plate Installed
