Help/advice with SoftBrake Tombstone Taillight Choices
Hi,
I have a 2007 Deluxe and I'd like to move the license plate, probably, to the side. And also get rid of the factory taillight housing with the mount for the plate above.
J&P have two housings which look identical in the pictures, but one says for plate NOT under the housing (340-760), and one says plate with or without bracket for under the housing (340-755).
So my question is, why not get the one where you may or may not use the under housing relocation bracket, as that will give more options. I imagine there's an opening on the bottom for the bracket? Is that opening very noticeable? Will it allow water/moisture/dirt in if I go with a side mount setup instead?
http://www.jpcycles.com/product/340-755
or
http://www.jpcycles.com/product/340-760
I'm leaning towards the 340-760 housing with a side mount bracket, but I figure why not leave my options open if there's no downside to the 340-755 housing being "open" on the bottom. I can't find any pics online of the bottom of either of these housings so I'm hoping those with more experience can please advise. Thank you!
or
Look here ... This matches the 2nd link you had for J&P 340-760 ... SB-TSH says "This product allows you to relocate your license plate elsewhere for a much cleaner and sleeker look."
https://softbrake.wpengine.com/produ...light-housing/
This one SB-TSH-N says "This product is designed to be used with SoftBrakes’ License Plate Relocator for a much cleaner and sleeker look"
https://softbrake.wpengine.com/produ...ght-housing-2/
I used their License Plate Relocator to below the Tombstone so this 2nd one is the one I used but I think you'd want the 1st one
Thank you for the reply, GinsengSullivan!
See in the pictures they look identical, but I imagine on the one you have there's a space for the bracket to fit through the bottom? What if I had yours, but without the bracket down there, would the opening underneath be a problem? Thanks.
I dont think it would be much of a problem but I'll check tomorrow and see
That does help a lot, thank you! I'm probably going to go with a Kuryakyn side mount for the plate, but get the housing like you have so my options are open down the line and I could get the under taillight bracket later if need be.
Can't ask GinsengSullivan for any more than he's already done, but if someone who has one of these could post a picture of the bottom that would be really great. Can't believe there aren't already pics from all angles anywhere online.
