Having a problem with new speedo/tach combo with the changing colors etc, gas gauge....
I did the install as manual stated an did the 31 miles deal,but the speedo doesn't go into setup mode to get gas gauge to work or change colors an all that stuff. Anyone have this problem or know what to do about it....? Speedo an tach does work, just nothing else
I bought this same speedo and had the exact same problem. Turned out that the speedo didn't like the fact that I had had an aftermarket electrical component (amplifier positive lead) spliced into a specific accessory wire under the seat.
Worked like a charm once I unhooked the accessory.
I have had VIN errors ... I changed my battery and blam ... they warrantied it then they ****er did it again ! when I disconnected gauge and took off the tank .......
My turn signal indicators both stay solid on my dash, even if I'm not using them but when u do use them they flash like normal... wld that have anything to do with anything lol?
