high speed wobble on custom softail
I am new at this... started a forum once. Give me a break if I don't respond right away.
I have to share this because it is new you can use - added quick disconnect fairing and hard bags to my CVO Convertible. I have had high speed wobble since. Been trying to make sure all is right and then I put a back seat on my bike and rode b*tch to see what it would do. I normally had the wobble at 80 and we took it out over 110
My next step is to get a couple turns on the shocks in the rear. Anyone else have ideas (don't tell me to gain weight!)
Sunny
Sunny
Wobbles and instability are "usually" a sign of not enough weight on the front-end. All the things you added takes weight off the front, even the fairing.
I'd crank up some preload on on the rear.
What I state assumes you don't have other issues like loose steering head bearings, forks that have leaked fluid, etc...
Marilyn Sunny Strauss (09-06-2017)
I'd check the torque on the fork nut, I heard HD raised it at one point but I read that a long time ago an do remember what bikes they raised it on...I added a little windshield that has the little curved up lip an it seems to help high speed stability, like it added a little down force on the front forks.
you can also:
have the tire checked for balance, check front/rear wheel alignment, if using a spoke wheel check for a loose spoke
you can also:
I added the fairing to the front end, it had a small one. I would say maybe 15 pounds heavier. I have had the front end checked out and tightened up the head bearing.
I spoke with a frame builder yesterday and he said he may be able to help me put some weight in the back.
you can also:
you can also:
it's a wind vest....I think LRS Long Range Shields makes curved shields that fit the HD windshield frame.
https://longrideshields.com/collecti...fatboy-softail
I had one on my Electra glide an I was able to get a shorter shield for the look but the kick up from the curve gave it the same protection as a taller straight one.
