Quiet 2 into 1 exhaust?
RE: Quiet 2 into 1 exhaust?
Don't know about fat cat I have the pro pipe and it isn't quiet but no where as loud as long or short shots. It does have a different sound than the twin pipes.Did not dyno installed power commander, pipes and screaming eagle air filter set up myself. You can feel a large increase in power from just off idle all the way up.
Resurrecting this one myself... Sorry guys.. hehehe
Appears these D&D Fatcats are the hot tamale around the forum these days.... I love my rinehart staggered duals except they are pretty loud at times I'm not into it but love their tone except for a little bit too much "crack" when you punch it... And, I've got the typical drag-pipe low-RPM blues... If I open it up in lower RPM's to pull, it will actually start choking spitting and bucking like a bronco... I think that may be something that can be tuned out as it's a stock carb bike with K&N filter and dynajet kit installed... Probably just some jetting or maybe idle-mix adjustment?? But anyway, I've been considering these 2 into 1 fatcats... for giggles.
Would you say they're as loud as Rinehart staggereds or similar drag style pipes... "low-end rumble" or "high-end crack"??
They look like they'd also fit with my low-hanging fat-a@@ iron max bags too.. a good thing..
They do look sharp.. better than the VH's or the RH's 2-1's I think... We'll see if I can get my staggered scoot tuned with the RH drags, I'll keep 'em, but these D&D's look like THE alternative if I cant.
Bassani Road-Rage is a great sounding pipe. Not too loud when you're putting in and out of the neighborhood......and yet when you crack it.............she really comes to life.
Love the pipe.......pretty much the same as the D & D for performance, but I like the sound much better.
This pipe doesn't get the same "pub" that the D & D does, but you should go check out Latus Harely and see their Dyno-Sheets. They have one that shows the Road-Rage against the Fatcat. If you like the power to come on at a slightly less RPM, then I think you'd really like the Bassani.
Just my .20
[IMG]local://upfiles/10807/60C926A1D9104282929C8894583ABD65.jpg[/IMG]
Just my .20
I just swapped out my VH BSS for the new Rinehart 2 into 1. I really like the new set-up. The pipes are quieter than the Vance and Hines but still have some bark to them when I hit the throttle. Nice deep rumble tone. Chrome fit and finish good. Check them out. Good luck.
AmericanMuscle
09-28-2012 04:02 AM
