dose any one know this code?
Hi,
I could be wrong but I think what you are seeing is PSSPT, which is the initial display to let you know you've entered diagnostics.
If you do a search of the forum for speedo diagnostics you'll get accurate information as to how to progress further.
If you press the trip button quickly while the above is displayed, it will take you into each section of the dtc's.
P = ECM dtc
SP = speedo dtc
S = security/ indicators dtc
T = tachometer dtc (if you have a tacho.
You must have the kill switch in the On position.
Like I say, do a search and it'll explain it much better than I've done.
If you need further help it is a good idea to say the year, model of your bike and a description of what is happening.
Good luck.
P = ECM dtc
SP = speedo dtc
Good luck.
