so i have about 700 miles on the new softail slim s...the stock seat sucks its terrible, iv read nothing but good things about sending my seat to mcc or should i spend the extra money and go with the mustang wide tripper diamond stitch? or does anyone have any other input on another brand or route to go, i'm not too tall on the shorter spectrum of 5'5-5'6 and weigh about 175
Yeah, the stock seat on the FLSS is not very good for even an hour ride. Not the worst stock seat I've ever ridden on, but definitely not meant for long rides.
IMO, the problem with the stock seat is the padding is too thin and too soft. So it becomes you are basically sitting on the pan...
I've not tried MCC or Mustang seats. I went right for the Corbin Solo saddle. I've used Corbin on my other motorcycles that requires an after-market seat.
Yesterday, I went on a 4 hour ride with about a 10 break in the middle. The Corbin Saddle was a million times better than the OEM seat. Corbins need to break-in. So it wasn't like it was SUPER comfortable, but I wasn't squirming after 30 minutes and my legs definitely did NOT go numb.
The only potential issue I see is the Corbin is a taller seat than the OEM seat and the Mustang. If you go to their site they have a tool with a slide bar which you can move back and forth to see the stock seat and the Corbin seat. So that may be a consideration for you....
Yep, the stock seat sucks. I bought a Saddleman and absolutely love the fit and finish and the way it looks. It's more comfortable than the stock seat and keeps you from sliding off the back when you roll on the throttle in first and second gear. But it still has quite a bit to be desired in the comfort area. I wanted a little more support and padding and went ahead and got a mustang wide tripper and it's more comfortable than the saddleman seat for any extended riding. I'm going to keep both of them the Saddleman seat for around town and short rides and the mustang for any extended riding. If I had it to do over again I would probably start with the Corbin.
I have a corbin for 2 up riding...it's def taller than the stock an mustang seats. I think mine is a Mustang Day Tripper but I'm not sure...got a good deal on it on ebay. I couldn't take 30 mins on the stock seat now I ride 2 hours no problem. I don't do much distance riding so the Corbin just sits in the garage
Yes, we all agree the stock seat does suck, but my problem was every aftermarket seat seems to push me forward, which is not acceptable. I found a solution that works for me and now have no issues with the stock seat.
For trips less than 2 hours, wearing performance underwear ( 90% polyester ) makes all the difference in the world. They keep the moisture away from your skin and are as smooth as silk. I find that cotton underwear, once wet with sweat, acts like sandpaper on my tailbone. Dick's sells Reebok for around $10.00. Some brands are very expensive but these work fine.
For all day trips, along with the above, I use a black sheep skin cover. I have one that has elastic around the edges and goes on and off in seconds. I did a 6 day trip in July, averaging 6 to 8 hours in the saddle every day, with 90+ degree heat, and had zero issues.
