MC Jack
I haven't had a problem with my harbor freight jack an it's 7 years old...I got the coupon an I'm gonna drop the $300 on a harbor freight lift table. If you have room that's the way to go....I'm gonna have to toss some junk to make some room...I also have one of those $50 scissor jacks an it's good for oil changes an stuff that don't require much height. when I had my lowered softail I used to just put 2 squares of 3/4" ply wood down an roll the bike on those then slide the jack under it.
Get a Sears or HF aluminum jack and a Redline dolly.
The entire setup should set you back $250 or less.
The aluminum jack will get the lowest to the floor as much as anything available and other than the bike sitting on the ground the Redline dolly provides as much if not more stability than any option out there (other than a table lift)
Here's the link to my recommendation:
https://www.hdforums.com/forum/gener...ly-review.html
Bone Doc (08-13-2017)
The OP is obviously a newbie or they wouldn't be asking for either a "Lift or Jack" recommendation.
As you know other than perhaps oil and tires this subject has the most information on the forum.
I assume the OP was referring to a jack and not actually a lift.
The post states "one that will fit under my Softail Delixe"
But you know what they say about assuming.
Iceman24 (08-13-2017)
Definitely...if the bike's lowered then some of the jacks are iffy at fitting w/o placing bike upright. Lifts are nice, if you have the space, but I haven't found any reason to replace my J&S jack...used for three bikes and going on 7-yrs of use with no issues. Actually getting ready to use today for my exhaust swap on the Dyna.
Get the jack that suits your needs and wallet. If the jack slides under your Deluxe, great. If not, roll the bike onto 2" high blocks and then roll the jack under the bike.
Don't overthink it.
Sorry for the confusion on my part. Yes, I meant a Jack. I emailed J&S twice in the last week to see if it is low enough to slide under the Deluxe, but never have got a reply. I am wanting to know what is the best recommendation on a jack that will fit under the Deluxe.... or will I have to use something under the wheels in all cases? Sorry to those I offended by asking a MC jack question.......I would not have asked if I knew. Thx to those who replied with suggestions.
