Rocker C Drive Belt
Old 08-06-2017 | 02:13 PM
mmesa005's Avatar
mmesa005
Default Rocker C Drive Belt
While I have the bike apart I decided I would changed the swing arm bearings and drive belt. I called my local dealer and he stated that the belt 40058-07 was not available from Harley at this time and he would have to find one from another dealer. Curious if other's who use this belt have had the same experience and if so did you go with another brand of belt? Anyone know why the belt is not available from Harley, redesign?
Thanks!
Old 08-06-2017 | 06:33 PM
Rocker B's Avatar
Rocker B
When HD started making the Breakout, they changed from the Rockers 133 Tooth belt to a 132 Tooth...You can use it on your Rocker, it will just move the axle forward a little. It'll make it a little tighter to do a 30/70 trans sprocket/rear pulley mod, if you ever do, but it's still very doable...I haven't had a reason to change my Rockers belt, but if it's not available if/when I do, I'll use the Breakouts 132Tooth...
Sarah93003 (08-06-2017)
Old 08-07-2017 | 07:50 PM
mmesa005's Avatar
mmesa005
Rocker_B,
Thanks for the advice, I will keep that in mind!
kiwiharleyrider54
17
10-16-2022 05:07 PM
Ice-Child
04-19-2018 10:29 AM
shrini23
11-11-2014 12:01 PM
Bill Murray
05-02-2013 12:22 AM
clayman
10-15-2006 03:08 PM
Quick Reply: Rocker C Drive Belt
