Primary chain adjustment
07-28-2017 | 06:39 PM
So I think I'm doing something wrong. I'm trying to adjust the primary chain tension on my 08 heritage but this looks nothing like the pics I see in the tutorials I saw online. Any help or advice wood be appreciated.
07-28-2017 | 06:44 PM
Nothing to adjust, that's self adjusting, may even be a hydraulic.
07-28-2017 | 06:45 PM
The photo is of the balancer assembly, not the primary.
07-28-2017 | 09:53 PM
If no access panel in the primary cover, no adjustment available.
07-29-2017 | 08:37 AM
Um, that is not your primary chain....
07-29-2017 | 09:01 AM
This has to be a joke...!
If you have your engine this far apart, and think that is your primary chain... you'd better let someone else put it back together...!!
07-29-2017 | 06:40 PM
Lol. The adjustment is under the head gaskets.
07-29-2017 | 06:48 PM
Quote:
Originally Posted by
Ddieselsmoke
Finally a serious response, thanks. I'll check under the head gasket tonight.
07-29-2017 | 07:12 PM
You don't have to go that far! I adjusted mine right under the rocker box gasket. Then realized all the problem was a bad front caliper.!
07-30-2017 | 12:07 AM
Y'all are all wrong. Clearly, the problem is that he is low on blinker fluid!
