Narrow Apes?
RE: Narrow Apes?
It's a Ness taildragger. You can get them straight from Ness or third party sites like www.meancycles.com .
RE: Narrow Apes?
What's the front fender, stock heritage? I see your rings are powdercoated black. That is what I want to do as well. Did you buy them, or have your stock ones powdercoated? You pretty much have the bike I envision mine to be. It's going to look great. Keep us posted. When it's all said and done, this could be a serious BOTM contender.
RE: Narrow Apes?
The front fender is a Ness frontdragger. I had my stock rims powdercoated and the white walls added. They did not want to scrape upthe rear wall while test fitting the back fender, so it will get put on at final assembly. I looked for some powdercoated rims on ebay, but never found any that were the same size. PC'ing isnt too expensive, its the labor of taking the wheels apart and messing with the spokes that kills you! Search the member list for jhogan20. After I started my bike, I found his and i was the same way. He was helpful on a few issues.
RE: Narrow Apes?
The very bottom of the swing arm I'm guessing? It doesnt drop that low. It has a lowering kit on it and can go a lil bit lower. I've got about 2" of travel right now between the tire and the top of the fender. I'm guessing I'll bottom out when I hit a big bump. I kept the stock struts, but I've seen custom struts on a bike like this that attach higher in the fender and drop that fender real low...
