Under seat box ID needed
jpowell490 (03-08-2017)
It's between the front (power) harness and the rear light harness. So like Smitty says, likely a run/brake/turn module or maybe someone had LEDs on the back and removed them before you bought it and left the load balancer there.
Turn your lights on and see if the rear turn signal lights also act as run and/or brake lights. On that year bike they would not unless you have the module.
If it's a leftover load balancer for LED and you don't have LEDs, you don't need it.
Another good point. It may be a module to make the brake light flash. Didn't think of that because my run/turn/brake modules have switches on them to inactivate the brake flash function or to choose a flash pattern. His module may just be a single pattern unit.
You are exactly right. Here it is:
http://mstore.harley-davidson.com/st...11-6946106b--1
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
