Ape hangars
definitely not in a rush . I like that idea seeing that it is winter . Riding up to laconia in June so I want this thing looking legit . So your saying you can order these cables to ACTUAL length. If I got my bars and risers and mounted them do what u said and I would be able to order my cables exactly the way u said .
I found it easier to just measure the difference from the old bars to the new bars, which was 8" and ordered all my cables 8" over stock length and it worked great.
One thing I didn't think about is I lowered the rear 1.5" and 2" in the front AFTER I did the bars and cables which then made my front brake line a hair to long. I was able to re route it and move some clamps to make up the extra slack and it still looks great, but if your planning on doing a bunch of stuff this winter like I did and lower the bike, just take that into consideration. But it really didn't make to much of a difference like I said. In a perfect world, I should have lowered the bike first. It only affects the front brake cable.
Edit: check out magnumshielding.com they have black stainless cables as well
I ordered my cables from magnum shielding, great company that you may want to check out and see if they have cables you like. With magnum shielding you can either order the cables x" over your stock length or you can measure the exact length you want each cable to be.
On the top right of their web site go to menu, brake lines, non abs, then E-Z align single disk
TittiesnBeer
03-01-2017 08:33 AM
