Grinding sound in primary
Old 01-05-2017, 04:47 PM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
Received 2,955 Likes on 1,438 Posts
try a piece of wood in place of that.....I heard someone use a brass hinge between sprockets......
Old 01-05-2017, 04:55 PM
chrisj49's Avatar
chrisj49
chrisj49 is offline
Originally Posted by Clammy
You'll need this (it goes between the sprocket and the chain):
http://www.ebay.com/itm/Harley-David...1WWdpl&vxp=mtr
Cheers!
You can make that tool using cheap white kitchen cutting boards. Cut 3 strips, offset them, put a bolt through it. There is a series of videos on Youtube about replacing the stator that show how to make it - really simple.
Edit :
He doesn't really show it being made, but you get the idea.
Old 01-05-2017, 05:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,418 Likes on 5,017 Posts
Originally Posted by cencal
i will gob on some red loctite.
Use the proper grade Loctite as specified in the Factory Service Manual, and use the correct amount....
Old 01-05-2017, 06:42 PM
Clammy's Avatar
Clammy
Clammy is offline
Received 1,905 Likes on 814 Posts
Edit : https://www.youtube.com/watch?v=djEwdOzfBI0
I figured for $8.50, I'd just buy the tool, hehehe...
Cheers!
Old 01-05-2017, 06:50 PM
cencal's Avatar
cencal
cencal is offline
I actually ended up using a flywheel crank that I already had to grab the gear on the clutch. Worked well but if I was an octopus with 8 arms it would have been easier.
All back together and took it for a ride for about 20 miles or so and all seems good.
Thanks for the help everyone!!!!!!!!!!!!!!!!!!!!!!!!!!!
As-21
EVO
04-11-2019 01:42 PM
carlgrover
EVO
08-07-2015 05:20 AM
nomad billy
04-03-2015 01:39 PM
KW_74_IH
Ironhead
01-30-2009 12:40 AM
piperman
10-13-2008 11:52 AM
Quick Reply: Grinding sound in primary
