103 take off
103 take off
I picked up a 2011 103 topend today for $350 with 19,000 miles. He bought the tire shredder kit so he sold the old stuff. Included heads less ACRs, pushrods lifters cams cylinders and pistons. Cylinders look in great condition wear wise. The cams lifters and pushrods for obvious reasons I'm not using. I have a new set of SE-204s what is needed to bolt this on or should I do a freshining up?? My bike is a 09 fxstc
I have SE-204 cams too on my 103 and pretty happy of the result.
When I installed cams I also ordered:
SE Perfect Fit Pushrods 18400-03
Heavy Duty Clutch Spring
Cam Spacer Kit
Drive Gear Retention Kit
SE High Performance Inner Cam Bearings
Also added the SE High Volume Oil Pump 62400001
37951-98
25928-06
25566-06
24018-10
If the engine runs well I wouldn't do anything else than installing the SE-204 cams with the other parts I mentioned.
If you want to improve a little bit more the engine on multiple aspects you can install the SE Cam Plate that matches the oil pump (there's a kit). It's also possible to fit a slightly bigger throttle body, 50mm instead of 46mm and CNC Ported Heads to have the engine breathing and performing better.
Obviously a ECM map upgrade it's necessary to have cams working properly...
