thinking about a softail for my next harley
Old 11-14-2016 | 05:20 PM
ajcjr's Avatar
ajcjr
Thanks for all the advice. I think all the softails look cool. I am definitely going to test drive them and look for a 16 leftover. Anything different on the 16s to 17s?
Thanks again for all the input, beautiful bikes everyone has!!
  #52
Old 11-14-2016 | 05:33 PM
Zakk13's Avatar
Zakk13
No difference between the 16 and 17 in the Softail line as far as im aware. You will not regret going the Softail route. I loved all my Softails that ive owned over the years. My Favorites were my 2009 Night train , 2012 Fatboy Lo and my current ride a 2016 Fatboy. Softails have such an amazing IN the bike comfortable searing position that is unmatched. And there sexy as hell.. Softails by far are my favorite Harley.
ajcjr (11-15-2016)
  #53
Old 11-15-2016 | 12:16 PM
rquest's Avatar
rquest
For years I wanted a softail before I got mine. (even had a hard tail once) The thing I like the most about them is how clean they are, "a perfect obtuse triangle." (excuse my pixelated picture)
ajcjr (11-15-2016)
  #54
Old 11-16-2016 | 07:36 PM
Gman in NC's Avatar
Gman in NC
Three or four hours a day is nothing. A Heritage is probably the best package for you. I'm almost 70 years old and my '09' Heritage is the easiest to handle bike I've had in a long time. Planning on riding it for a few more years for sure.
  #55
Old 11-19-2016 | 11:10 AM
alexknight2000's Avatar
alexknight2000
Default What adjustments
What adjustments have you done as would be interested in seeing if I could use the information.
regards
Alex
Originally Posted by LXT
. I was tired of dragging boards on mine so I did a lil customizing (myself) & I can hit the twisties as well as any cruiser out there - so as far as the sloptail comment nutpump - you don't have a clue!!!
OP you cant go wrong with any bike in the softail line up or an HD in general!
  #56
Old 11-20-2016 | 08:17 AM
LXT's Avatar
LXT
regards
Alex
Alex,
All I did was put on a set of forwards (acutronix), they`re not that expensive but....fitment issues & adding on to them can be a PITA - I did not have these problems.
The problem with forwards is that you usually have to remove the crash bar, what I did was make a set of extensions coming off the front motor bolt, the kickstand side is a trial by error due to the weld for the kickstand spring.
Just bought some small flat steel already pre drilled/holed at lowes, primer & black paint hides it nice, this was used to mount the crash bar to as now the floorboards are gone.
I have the mustache crash bar so the space to get to the shifter / brake pedal leaves one making adjustments on those but no big deal - to get as much foot rest as possible I bought a set of 3-1/2 inch male end adapters & installed kuryakyns ISO peg mini floorboards (I think that's what their called) with stirrups.
Ill try & get some pics up - not sure how to do it?, I did this on my 02 Heritage so not sure what your set up is like. The only bad thing is with my set up using the mustache crash bar - to get to the shifter or brake pedal if you like wearing a thick soled boot you might have an issue getting between the crash bar & shift/brake pedals. other wise if you have standard crashes - no problem.
to me it was a trade off, I wanted comfort (stretch out & relax) & wanted to be able to ride through a turn/bend without dragging. Two up hitting the curves would scare the hell outta my wife - Now, No problems & I can lean hard - love it!
Keep in mind as with all things HD related, to attain this will cost a chunk, I went with the Acutronix due to them being a better price, you`ll hear buy this one or that - but honestly you can rack up some money in name brand & it all performs pretty much the same!
Good Luck & Ill try to get some pics up
alexknight2000 (11-20-2016)
  #57
Old 11-20-2016 | 10:04 AM
alexknight2000
Default forward controls
Thanks for the write up appreciated. If you can get photos that would be great as sounds like this could be exactly what I want. Alex
Alex,
  #58
Old 11-20-2016 | 10:21 AM
pigfoot63's Avatar
pigfoot63
Default Slim with a few changes.
  #59
Old 11-20-2016 | 03:15 PM
09fitz's Avatar
09fitz
Originally Posted by pigfoot63
Looks good. I like those Slims.
jeff137
10-13-2019 12:49 PM
jimmy z
11-20-2011 01:23 AM
bjewell
06-12-2010 10:53 PM
craigp
03-12-2010 02:14 PM
ChrisA351
05-15-2008 09:06 AM
Quick Reply: thinking about a softail for my next harley
