turnsignal blues !!!!!!
#43
RE: turnsignal blues !!!!!!
ORIGINAL: Mayfair
You could always re-locate them under the floorboards like I did ...
[IMG]local://upfiles/34049/8952EDAA4816477AAF8B55BC890D25C7.jpg[/IMG]
Stoneman, is it both the front and back T/S's together, or just the front/back ones?
When I was doing the wiring on the back ones there was some weird **** going on 'cuz one of the wires was loose and came out of the connecter. I was putting the neg battery back on; turning ignition; and then hitting the indicator.
On the front ones you might wanna check the main pin adapter under the tank, right hand side, it's not as far back as the other electrics and only has the black/purple wire going in, tank only has to go back maybe 2 inches. Check that the parting that meets on that side goes off properly to the left and right handle bar correctly. Make sure that parting is not pinched.
I say this 'cuz when I changed the bars I had the left one on the right and visa versa...... It screwed everything. I also pinched one putting the tank back on temporarily, and I clearly saw the pinch mark. When you check them make sure they are secured by the little white thing on the back of the adapter that holds it to the little hole in the rubber which is tied onto the frame.
Pttttfff,...... man, i hope you understood that.
#44
#45
Sorry i havn't been on in a while thanks for all the help. So here it goes i have checked all the bulbs 2,3,10 times they are fine. I have checked all the wires they are all good no breaks or pinches, "good wires". I still have yet to find cause of turnsignal blues, I spend too much time riding, i still have a good arm, works every time i use it hasn't failed me yet. Thanks to everyone.
STONEMAN
STONEMAN
