Need help please!
Old 09-10-2016, 11:09 AM
Tim Woody's Avatar
Tim Woody
Tim Woody is offline
Stage II
Default Need help please!
I have a 2012 Fat Boy Lo. A couple of days ago, I went to jump on my bike and go for a ride but it wouldn't start. When I turned on the ignition, the lights and displays in my odometer just flashed instead of staying on. Then I noticed the security light was staying on longer than normal. At first I thought the battery on my bike, I checked it and it was fully charged. I called one Harley dealership and they informed me to change the battery in my FOB's. I swapped both of them out and still no luck. I spoke to another dealership and they told me to check ground wires and ground straps. They all checked out good. Today, when I turn the ignition on, everything comes on like it should, but when I hit the run switch, everything starts blinking and the fuel pump does NOT kick on. Other than loading it up and taking it to a dealership, I'm hoping there is an answer out there. Any help would be greatly appreciated!
Old 09-10-2016, 12:23 PM
hattitude's Avatar
hattitude
hattitude is online now
Received 8,262 Likes on 4,437 Posts
Sounds like the security module (TSSM) is acting up...
I'd disconnect the battery, check all the connections (+ & -), then reconnect the battery...
I've did that to my truck once, when having an electrical glitch. It let all the computers in my truck restart.
Not sure if it will work for a Harley ECM/TSSM, but worth the try...
Old 09-10-2016, 02:03 PM
Tim Woody's Avatar
Tim Woody
Stage II
I checked the battery. Disconnected and cleaned posts and terminals. Even went as far as trying another battery and still nothing.
Old 09-10-2016, 05:53 PM
tpr2343's Avatar
tpr2343
tpr2343 is offline
6th Gear
Try the wiring to the starter, sounds like its loose.
Old 09-13-2016, 09:50 PM
oct1949's Avatar
oct1949
oct1949 is offline
Is your bike stock or have you or someone rewired anything.???
Old 09-13-2016, 09:56 PM
hspring03's Avatar
hspring03
hspring03 is offline
I'd say it's FOB related. You switched the battery in the FOB's with new ones or each other? Get new ones..... And, it's real easy to put them in upside down. double check...
Old 09-13-2016, 10:01 PM
saltlick's Avatar
saltlick
saltlick is offline
Its the security system guaranteed. Its either the FOB or the system itself is malfuntioning.
Old 09-13-2016, 10:10 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,416 Likes on 1,584 Posts
Either get a new battery or put a meter on the ones you have, Yes make sure
they are in the correct way.
Without trying to start it - with the new battery in the FOB, just sit on the bike and stand it up off the kickstand. If security light start flashing then it FOB or TSSM. If you have 2 FOBS make sure to try both, if same results it's probably not the FOBs.
?? Hit the Run Switch?? Turn the ignition on, listen for the fuel pump, before you try the START button.
I noticed this was your 2nd post and you are a new member. Just to make sure - there is a Run/Kill switch and a Start/Ignition switch. Make sure the Run switch is in the correct position. It Happens and is easy to bump to the Off position.
Old 09-15-2016, 04:19 PM
Backdraft161's Avatar
Backdraft161
Backdraft161 is offline
When u try to start do u get the turn signals to start flashing. If so then you will need to disarm the security system. There is also a transport mode and if not cleared it will not start as well.
I had those issues and just had to figure out how to disarm the system.
Hope this helps.
Old 09-17-2016, 09:58 AM
oct1949's Avatar
oct1949
oct1949 is offline
HEY Woody ---Just wondering...
did you ever git it fixed, if so what was the prob.... when you ask a question in here we like to know how or what you did to resolve it.
Quick Reply: Need help please!
