FLSTS rear turn signal visors
Hi all, Christian from Italy. I have a red/white 1997 FLSTS..I have a question..Do You know the HD code Nr for the all chrome Eagle Wing REAR turn signal visors?
I already have the all chrome Eagle Wing visors for headlight, passing light and I just found the chrome visors for the front turn signal (code Nr 67914-95T)
Before buying these, I would like to know if does exist and which code nr have the REAR turn signal visors.
Thanks
Thanks
Welcome to the forum from Texas, USA.
The reason you cannot find turn signal visors for the rear is that the visors only work with flat lens turn signals. If your turn signals are stock, the front ones are flat lens but the rear ones aren't. For you to use turn signal visors on the rear, you would have to install flat lens turn signals. The visors for an FLSTC would work on an FLSTS as long as you had flat lens turn signals.
The part number for the chrome Eagle wing FRONT turn signal visor is 67735-91T.
The part number for the chrome Eagle wing REAR turn signal visor is 67738-91T.
Front
Rear
Here's what they look like on my Heritage (FLSTC)
Front
Rear
I don't know why, but in my case the front visors would have worked just as well on the rear. Although Harley makes ones they say are for the rear with a different part number.
There is one other option but your front and rear turn signals must be the same style, I mean identical. That is to buy two sets of front visors and use one on the rear. The worst case scenaro is it won't work and you'll be out a small amount of money. Best case it will work as desired.
Good luck.
I don't know if you found your lights yet. I had the hardest time finding a glass lens for a classic car I'm restoring and wasn't about to swap for new tail lights. Contacted Tail Light King and sure as you know what, he had what I needed. He carries motorcycle lights...
https://www.taillightking.com
1911man
08-23-2012 12:22 AM
