2005 softail swingarm fit 2007 + up
My friends 2006 Fatboy with a 200mm rear tire had a swingarm just like my 04 Duece with a 160 tire. His worked because the rim size was larger and let the tire clear the caliper and it had a rubber band width drive belt.
I had it thinking I could run a bigger tire but they appeared to me the same. However, I could be wrong. I know his fender was wider and I did not take mine apart to see how a wider fender would fit since I had no wider fender option on my bike that I knew of. I rolled it on on ebay.
If you're after a wider rear tire under your bike, have a look at my thread. You might pick up some useful stuff.
https://www.hdforums.com/forum/softa...ail-build.html
kgb44
11-09-2008 08:26 AM
