Hello, I am new here and a new Rocker C owner. I was wondering if the Breakout rear fender and struts will fit my Rocker C? Any help will be greatly appreciated!
You need a few more pieces than that, but yes it will all bolt up
Thank you. Could you please tell me what else I need to do the fender swap? I'm thinking a licence plate bracket and taillight and maybe a seat?
Thanks again !
Thanks again !
Here a link showing all of the parts that make up the BO fender... http://partsfinder.onlinemicrofiche....=41&c=0&d=2013 FXSB SOFTAIL® BREAKOUT 103B (BFV) FENDER - REAR W/ SUPPORTS.... You would also need lights, wiring, and a plate bracket. I think you'll also need a Badlands Illuminator module/load equalizer to take care of the different lighting, and yes a new seat unless you have switched out the stocker and can modify it....
Thank you again. There isn't much info out there on the internet. I appreciate the input! I want to put a taildragger rear fender and use the head cups for another 3° of rake, a velocity stack, Vance & Hines big radious pipes and fuel management any thoughts??
I use an FP3 on both my bikes, it's a great little tuner...I highly recommend it!!! Especially with the V&H pipes, the maps are right on. It has a bunch of cool features and is automatically updated when new features become available. You can see real time data, read trouble codes, it handles cam upgrades and is simple to use with a phone or Ipad. You can download the free FP3 app. and try it out in "DEMO" mode...
What year is your Rockers? The 2011'same are canbus so no load equalizer would be necessary, the 08-10 would all depends on what style lighting you'd run
