Softail Slim S 117 upgrade
Old 08-09-2016 | 05:19 PM
Waynelovatt@yahoo.co.uk's Avatar
5th Gear
Originally Posted by soft 02
As far as tuners I prefer FuelMoto. They also would have a good opinion on cam/head choices. They can pre load the tuner with your engine combination.
http://www.fuelmotousa.com/p-28398-d...er-vision.html
Cheers ..... I have looked at the Power Commander V as an option as it seems to have the capability for what I need
Old 08-09-2016 | 05:20 PM
soft 02's Avatar
soft 02
Give Jamie or Brian a call. A few minutes on the phone might help you out a bunch. They will take the time to help you out.
Old 08-09-2016 | 05:43 PM
yobtaf103's Avatar
yobtaf103
Hi, Wayne
As stated the 117 race kit, giving good results , guess with such a new bike you'll get a HD dealer to fit it?
MY choice would be HD heavy breather to suit 58mm TB in kit
Exhaust my fav is a supertrapp supermeg, performs well can adjust sound if required.
£250 street tuner is not the full cream SE pro tuner £420 but i would avoid
trouble i found could not get a real good dyno tuner here in UK, most do not like using it, spoiled a 107 build because of that !
Lost faith until i got a Dynojet Power vision they send a start map then can autotune it in, then i went to Dynojet HQ preston to get a final dyno tune.
Oh btw think Chester HD may have an August 20% discount, need to register/login to their online shop, should then see code.
Waynelovatt@yahoo.co.uk (08-09-2016)
5th Gear
Exhaust. Well if money wasnt an issue id have a SS Burns pipe but too pricey for me.
Had my heart set on Shadetree Fabrications black 2 in to 1 retro fishtail or shark tail as it's similar in style to the exhaust fitted to the old WLA. Unfortunately STF said it wouldn't be suitable for my engine size.
Old 08-09-2016 | 05:50 PM
soft 02's Avatar
soft 02
Im running a D&D fatcat with the standard baffle. About the smallest I can go with this motor. Id like to run V&H but it would hurt my performance. Less selection when you get into the larger displacement motors.
Old 08-09-2016 | 05:51 PM
soft 02's Avatar
soft 02
Originally Posted by yobtaf103
Hi, Wayne
Jamie didnt have a base map for my combo either so I had it dyno tuned. Runs like a top!
Old 08-09-2016 | 06:01 PM
yobtaf103's Avatar
yobtaf103
Just to add , my 107 fatboy is now a 110' bolt on, cyl heads by Alex @ www.fastlaneheadwork.co.uk 123hp 121 tq did 117/114 on autotune alone before Dyno . 58mm tb T-man 625 cams 4.9g inj 10.6 comp.
Now purchased 117 cyl/piston kit for my softail conv
5th Gear
Hi, Wayne
Am I right in thinking the Dynojet power vision would require the screen mounting on the bars? Would rather something that can fitted in a discreet position. Again never delved this deep into bike mods so not really up on the tech. The power commander v looks like I could install it under seat?
Old 08-09-2016 | 06:15 PM
yobtaf103's Avatar
yobtaf103
Yes mount to the bars , but only while using autotune then dyno, once bike is dialled in can be taken off as final map is sent to ecm.
PV can be used for multiple bikes extra licence is £158 for each bike, other tuners lock to ecm as well but thats it
Alex i mentioned does this for customers who use his motor build services so a cost effective route, as do some US tuning shops.
Old 08-09-2016 | 06:19 PM
soft 02's Avatar
soft 02
Yup. Dont need to have the PV on the bike unless doing some tuning or data logging.
Billstreet101
03-04-2019 09:12 PM
Preppy_Lepew
2014-2023 Touring Models
15
01-13-2017 12:30 PM
marty442
Exhaust System Topics
01-07-2011 05:33 AM
Bomber Watson
10-14-2010 09:16 AM
turbo38sfi
06-12-2006 09:12 AM
Quick Reply: Softail Slim S 117 upgrade
