Slim speedometer issue
Old 07-05-2016, 09:51 PM
Littleredcrate's Avatar
Littleredcrate
Littleredcrate is offline
Default Slim speedometer issue
Hey everyone, I had an issue with my 15' slim's speedometer and wanted to see if anyone had some advice/had the same issue. Sometimes when I get on the throttle pretty good, when I hit about 45mph my needle will stick even though I know I'm going well over that. When I let off the throttle the needle goes back down but once I give it has it quickly jumps back up and sticks at 45mph again. Also, when I come to a stop, it will stay at zero but as soon as I start moving it quickly jumps up and puts me at like 20mph faster than I'm actually going. Once I stop and **** it off for about 5 minutes it's fine. I've read that it could be either a faulty speedo, a dirty speedo sensor or a faulty speedo sensor. Any advice would be appreciated!
Old 07-06-2016, 01:06 PM
gd59's Avatar
gd59
gd59 is offline
I had similar problems with my 2015 slim shortly after I got it took to dealer they called Harley sent a new speedo they installed it no problems since. I've seen quite a few people with this issue bad batch of speedos I guess. Not sure if there is any fix except replacing it. ( Thanks for your service Sir )
Old 07-06-2016, 02:26 PM
Br125's Avatar
Br125
Br125 is offline
I've read some other people having this same issue after it happened to my friend with a '15 slim. Seems that a replacement speedo is the fix.
Old 07-06-2016, 02:50 PM
Littleredcrate
Thanks for the info guys. Well looks like that's a good excuse to see if I can get a speedo/tach combo since it's still under warranty.
Old 07-07-2016, 05:56 AM
Tony S.'s Avatar
Tony S.
Tony S. is offline
My 15 Slim also has the same problem. I keep meaning to take it in to have it replaced under warranty.
Old 07-10-2016, 02:32 PM
KenRice's Avatar
KenRice
KenRice is offline
I needed to get mine replaced on my '15 as well. The ABS light (no ABS on my bike) is constantly on. Anyone else have this problem?
Old 07-10-2016, 10:28 PM
FFeric's Avatar
FFeric
FFeric is offline
We did over 100 miles yesterday. I thought a few times it looked like the needle would seem to be bounce a little when I was around 45. I will have to watch for it again.
Old 07-11-2016, 06:28 AM
gd59's Avatar
gd59
gd59 is offline
Had the same thing after 1000 mile service took it back in dealer made it go away don't know if there is a switch, fuse, or just disconnect the light but took about 10 min. to fix hasn't ever come back on ...........
Old 05-17-2020, 08:31 PM
hotdog41's Avatar
hotdog41
hotdog41 is offline
Stage I
I solved my speedometer condensation problem. I installed a Dakota Digital MLX-2011 digital speedometer on my 2018 Sport Glide. Nice easy installation. Bought it off of ebay.
Old 07-31-2020, 02:48 PM
frankman's Avatar
frankman
frankman is offline
Has happened on every Harley I have ever owned and never on any other manufactures bike I have ever owned, had mine replaced at 1100 miles already, may take apart and drill to stop staining from occurring.
Quick Reply: Slim speedometer issue
