HD Inverted Front Fork Help
I have no idea what the seal looks like or the material it's made out of (I've never seen one) but 11mm to 12mm difference is only .039" (just over 1/32" .0315"). If the seal is indeed not available, you could take the 12mm seal you found and shave it down to 11mm. You may can take a piece of sand paper on a flat table and holding the seal flat "sand" off 1/32" pretty quickly. Use the uncut factory finish side of the seal on the "contaminant" side and shaved side of the new seal on the "oil" side.
That's crazy if it's discontinued though
That was my reply exactly, I even called HD Customer Service, useless twits. I have a problem with them selling something that they can't/won't support especially when it disables the bike. I haven't ridden this season at all because the bike is out of commission.
Fyi
You have a product that was manufactured by Marzocchi. They had an office several years ago in California. Everything that is in those, I have found through trying to service them, is all different measurements and definitely not interchangeable with other brands with ready available parts. All are odd sizes. They were always very hard to deal with in the best of times. I tried searching for any dealers in the USA and I came up with nothing for you. Try going here (good luck):
marzocchimoto.com
You may try PM'ing 05train on this forum as he has a set from a long time back.
You may also try contacting the Andreani Group in Italy as all of their manufactured offerings are based on the Marzocchi. I do not know if they could help. When I contacted them (Marzocchi) in California, it was a waste of time for me. Hope this helps.
marzocchimoto.com
marzocchimoto.com
marzocchimoto.com
Thanks for the reply but I'm way ahead of you. I email Marzocchi in Italy and Enrico replied that they can't sell directly to the market but only to motorcycle manufacturers, but did direct me to the Andreani Group.
So I emailed them and got a reply from Luciano saying they are suppliers for the aftermarket and since they don't have a reference number from Marzocchi they would need the measurements of the seal to try and match it.
I emailed Enrico back asking if he could at least supply me with a reference or part number for this seal. No reply yet. I'm going to call my dealer back today and see if he can get me measurements of the seal, maybe a picture to forward to the Andreani Group.
So close, yet so far.
