Do I really need to replace screws?
Old 06-18-2016 | 07:55 PM
Mugsy666's Avatar
Mugsy666
Default Do I really need to replace screws?
Hi guys
Do I really need to replace the screws on my rear wheel? My manual says i need to put new screws on my disc and belt pulley. Do I really?
Thanks
Old 06-18-2016 | 08:01 PM
QC's Avatar
QC
Want some cheese with that whine??
I did eventually replace my Pulley bolts with some Grade 8 hardware so I won't have to do that again. I haven't had to replace the disc bolts.
Those bolts are supposed to be replaced because after stretching during install they won't hold the torque the same if removed. That's the theory anyway. I don't remember seeing anywhere that those bolts are "prevailing torque" fasteners that require replacement.
Being a safety item, you can make your own decision on whether to replace them or not.
Old 06-18-2016 | 08:03 PM
ROCKOUT Rocker Products
Sponsor
I just went through the same thing on my Limited.... replaced the rear disc. Manual says to use new screws, is pretty adamant about it. I mentioned it on HTT forum & everyone said just reuse them.
I had already bought & used new ones.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 06-18-2016 | 08:04 PM
asm481's Avatar
asm481
do a search on here and you will see many wheels ruined because of pulley bolts that fail, loosen and shear off after working the holes oblong and backing out. Harley says replace bolts for a good reason.
Old 06-18-2016 | 09:05 PM
Bone Doc's Avatar
Bone Doc
Just curious, what is your reluctance to replace $5-10 worth of bolts?
Old 06-18-2016 | 09:39 PM
Sixgunjr's Avatar
Sixgunjr
I need a new screw at least once a week! ��
Old 06-18-2016 | 11:53 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OP must have a Clymer manual. Doesn't know that there's a big difference between bolts and screws.
Old 06-19-2016 | 06:50 AM
smitty901's Avatar
smitty901
No go cheap and when it comes apart or fails blame HD.
Old 06-19-2016 | 07:03 AM
S.D.M.F's Avatar
S.D.M.F
Just use 3 of the original ones. Keep the other 2 for spares.
What would the manual know?
Maybe knock some wooden dowels in there instead.
Old 06-19-2016 | 07:05 AM
Dan89FLSTC's Avatar
Dan89FLSTC
There is not a big difference between a bolt and a screw...
The op is correct, the application makes the part a screw, because it threads into the part and is not secured by a nut.
Often you will see bolts in catalogs, parts diagrams etc, and the description will say capscrew.
Quick Reply: Do I really need to replace screws?
