Boarzilla Exhaust
No problem but need clarification as to where to measure from:
1. Exhaust tip is slash cut. Do you want from very tip of slash where the exhaust ends or where the slash begins at the bottom of the pipe?
2. Do you want the measurement from where the forward cylinder exhaust pipe curve starts which is right where the rear brake pedal is, or do you want measurements from each exhaust port straight to whatever you decide for Q1
break pedal portion to the bottom of the slash thank you very much!
