Can someone with a Breakout look at their rear ABS Sensor
Old 06-10-2016 | 11:24 PM
_Gir_'s Avatar
_Gir_
Originally Posted by SSTuner
Can someone explain? If you look at the touring bikes this pin is actually in a slot in the caliper bracket.
Correct, theirs has a better setup. You did it right, fully CCW against the stop. I had the same questions you had but it doesn't spin due to where it's resting against the bearing. Don't forget to zip tie the excess wire to the swing arm.
Asking for explanations about how HD has decided to some things is a bit of a rabbit hole. Sometimes driving a whole new 3rd party aftermarket due to less-than-ideal design. Such as the chain tensioner in the primary.
Old 02-23-2020 | 06:23 AM
Neil Harris's Avatar
Neil Harris
Stage II
Default I think the abs pin rests wherever it locates when you tighten everything up ,,, mine is against the bracket
Can someone with a Breakout look at their rear ABS Sensor and tell me if this is correct. Picture is taken from below and want to know if the "pin" in circle is correct by resting on the disc brake bracket, just doesn't look right, especially with the rotation of the wheel would cause it to rotate. Thank You
Old 02-23-2020 | 06:26 AM
Neil Harris
Stage II
Default 2015 dyna street bob abs pin location
[QUOTE=Neil Harris;18896143] 2015 dyna street bob abs pin position
Old 04-10-2020 | 06:00 PM
OSFG's Avatar
OSFG
I had same question as others here...this is a good thread....and is stopping me from worrying.
The following 2 users liked this post by OSFG:
RideNz (06-12-2021), u wish u could ride (06-05-2020)
rossWG
08-03-2021 09:56 PM
BALLS172
04-05-2014 07:09 AM
3illy
05-31-2013 04:31 PM
Bigbob88
08-07-2011 06:47 PM
traveler
07-06-2009 11:51 PM
Quick Reply: Can someone with a Breakout look at their rear ABS Sensor
