Hi guys
Need help on my clutch adjustment on my 2012 Fatboy.. After I adjusted my clutch i went for a ride.. After 60 miles i noticed my clutch cable has more play in it.. Do i do it all over or just tighten the cable only.?
Loosen the jam nut at the cable adjuster. Pull the lever a few times and inspect the gap. Adjust the cable 1/4 turns until there is no gap, do not over tighten. Pull the lever a few times and double check. Now adjust the cable in 1/4 turns until you attain the 1/16-1/4" gap. Pull the lever a few more times and double check the gap. Tighten the cable jam once satisfied. Quite a few videos on youtube to help you, 'How to adjust a harley clutch'.
