Why does it take so long to swap bars?
Local dealer quoted my friend 10 hrs to change to Harley tall boy bars. No intn'l wiring. No cable changes req. 06 E-Glide. 10 HOURS!!!
Needless to say he laughed and walked.
Local
Local
I just did my wife's Forty Eight last night, added Hollywood bars. I didn't change a thing, cable wise. But, I did run her wires internally... That was one of the easy parts. Her bike is a '14 and the connectors are tiny. Slid right through (no tight angles, no corners either!).
When I popped 'em on at first, i thought the clutch and throttle cables would be too short to run between the headlight and triple trees, like they are stock. But, I was wrong... I had to feed them BACK through. That turned my hour and a half of leisurely paced work into three hours with her giving me the stink eye about ten minutes from being done.
Had I left well enough alone with the damn cables, I probably could have been done in under an hour. But, I didn't do any new cables or wires, extensions, etc. And she already has a tank lift. It was cake.
But def more than two hours if going taller and internal, longer cables, etc.
