plugging O2 sensor holes in pipes???
Old 05-18-2007 | 11:32 PM
CLL375's Avatar
CLL375
Default plugging O2 sensor holes in pipes???
Just got in my new pipes for my 07 NT now I need to plug the O2 sensor holes...What can I use?
Thanks for your time,
CLL
Old 05-18-2007 | 11:56 PM
pococj's Avatar
pococj
Default RE: plugging O2 sensor holes in pipes???
Best thing would be some stainless steel pipe plugs.
Old 05-19-2007 | 12:10 AM
Hammer02's Avatar
Hammer02
Would a pipe plug be too obvious of an answer?
You get em at your local hardware store or Lowes.
Ask someone...they'll get you the right thing.
Take an O2 sensor with you so you know you have the right size.
Old 05-19-2007 | 12:16 AM
XTrooper3936's Avatar
XTrooper3936
I purchased a pair of zinc-plated plugs from this outfit. They also have stainless ones if that's what you prefer.
http://vertexnow.com/Verocious-Motor...ings-and-Bungs
I'm not sure a home improvement store like Lowe's would have the proper size as it's pretty much a vehicle-specific size. If you want to buy locally, you'd be better off going to an auto parts store. The size/thread is 18mm x 1.5mm.
Old 05-19-2007 | 01:32 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Do what Hammer said, just take an O2 sensor to Lowes or Home Depot and get a couple of short stainless steel bolts the same size. If you can't find any that are only 1/2" or so long. Get longer ones and use a hacksaw and grinder to cut them shorter and use a soft copper washer as a gasket.
BTW I believe it may be a metric thread,not a tapered pipe thread, so getting a plumbing pipe plug that fits right might be difficult.
Old 05-19-2007 | 02:14 AM
Hammer02's Avatar
Hammer02
It's 18 * 1.5 mm.
Old 05-19-2007 | 02:47 AM
ORIGINAL: Hammer02
It's 18 * 1.5 mm.
Thanks for the info, I though I remembered something about them being metric, but I wasn't sure what the actual thread size was.
Old 05-19-2007 | 04:24 AM
mopar's Avatar
mopar
Auto parts store help section. Oil pan drain Plug. Use copper washer. Used this setup on many V&H pipes on a VTX.
Old 05-19-2007 | 09:35 AM
XTrooper3936
ORIGINAL: Citoriplus
BTW I believe it may be a metric thread..............
Did you read my whole post, amigo? I mention the bolt/thread size.
Old 05-20-2007 | 01:27 AM
ORIGINAL: XTrooper3936
Sure did, then got an instant case of the stupids and forgot what Iread.
Quick Reply: plugging O2 sensor holes in pipes???
