Does anyone know anything about Ultima Rear Drive Belts. I see they are a lot cheaper on ebay than other belts. Harley wants about 210 for this belt. The Ultima is listed around 90. I have an 06 fatboy.
Considering that the inner primary and rear swing arm needs to be removed to install the rear belt, is the 30- savings going to cover the labor cost if the Ultima belt doesn't last as long as the OEM belt?
My INdy swapped it for $125.00 after I took the Primary off myself. Might want to change your swingarm bearings and bushings while you have that off...
I put one on my softail about 3 months ago and it was fine for a month then it started to slip i thought it was because it got loose so I readjusted it and it was good for about a. Week then it slipped again it was still tight my pullys are good. I put my worn out harley belt back on and have had no problems . sad to say price was right but belt was garbage
