Lamp Adjustment
Lamp Adjustment
I recently replaced my lights with DK Custom drop in bulbs. From what I see, if anyone does not see me coming down the road they are blind or they just got blinded by the lights. Now with that said. I don't want to blind people and get flashed. I have not drove it at night yet but was wondering if anyone has had any experiences with the DK Custom drop ins and not had to adjust the main lamp or if you did have to by how much did you adjust the main lamp?
I was also blinding oncoming traffic after installing the DK drop in and it took two adjustments to get the light where I wanted it. Parked the bike in the drive, marked front and rear tire with chalk, marked the top of the light pattern on the shop door with a pencil and then adjusted the light. Went too far down the first time so I parked the bike in the same spot (chalk marks)and adjusted again. Can't really follow the procedure in the shop manual as there is no "warm spot" with this bulb.
I can agree but you have to try. I do not think that they would hear no matter how load the bike is. However, I still have it bright and load.
I'm running the OPT7 drop in bulb. Same basic light. I wound up having to give my up-down adjustment screw three turns out to lower the light enough. The actual hot spot of the new drop in LEDs is larger than the stock halogen, so lowering it a few turns puts the additional light pattern back on the ground. And the high beam pattern worked out perfectly. And MAN does that high beam throw some light!
MANCHU DOG7
07-12-2007 03:48 PM
