Who's installed the Custom Dynamics breakout tail light
Part number cd1054 specifically. I know a few people here have done this and I SWEAR I have seen this problem present before. Just can't seem to find the thread. Hooked everything up...runs fine. But it is in constant bright mode and pressing the brake causes the lights to dim. I have the plugs set up with Black on the top left, blue on the top right, and purple/the other one on the bottom right of the plugs.
Ok I think I may have the pins screwed up since HD pulled them out when working on the fender. The service manual has the following setup:
Pin 1: tail (blue)
Pin 2: brake/turn (violet)
Pin 3: ---
Pin 4: Ground (Black)
Does anyone know off hand which pin is considered 1, 2, 3, and for within the harness? HD pulled the pins out before I got the fender back so it's been a bunch of trial and error here.
Pin 1: tail (blue)
Pin 3: ---
Pin 1: tail (blue)
Pin 3: ---
Pin 1: tail (blue)
Pin 3: ---
Every connector housing I've worked with has had the numbers on there - just gotta look for them.
Dynamn
Electrical/Lighting/Alarm
05-26-2019 07:47 AM
